Does anyone know the model# for incondessent dash lights. Not interested in LED's. Or if someone could tell me what these bulbs (current). Good to be back... Hello
1800S??? Leds in the speedo cluster.
What is your problem?
1800C = bulbs
Oil lamp is out, Pressure switch works but you see no voltage coming to it. Either have an open bulb or wire. It's been to cold here to work in the garage here. So I thought that I would buy a spare bulb so when I get into it on a warm day.
I find no info on what the X uses.
1800C is the ONLY model that uses BULBS.
All the other 1800s use LEDS for backlight and indicators.
Is the neutral indicator working???
Engine Oil Pressure (EOP) Blue/red stripe wire possibly has a connector at the main cable harness. Someone else had EOP failure at the connector recently.
You can also check the Bu/R wire at the 6 pin speedo connector.
Looks like you have a 1800S.
EOP---Bu/R------Bullet connector------6 pin connector--------speedo
I have a 1800S as you said must be LED, Neutral Light works... I'll check the connectors out too.
Thanks Hands & Feet.
