1 - 16 of 16 Posts
Hi there. I am posting a pic of my exhaust and I am hoping someone can tell if it is stock or if they can tell what brand? I purchased Ruby which is a 2004 1800s S2. As far as I can tell, she is stock minus the Mustang seat. The guy I bought it from said he pulled the baffles out and no longer had them. I have read that isnt a good thing to do as the engine likes the back pressure. I also would rather it not sound like it does. Hoping to find baffles somewhere on the good 'ol WWW and put them back in. Anyway, up for ideas on brand and or where I can get a couple baffles to re-install. Thank you :smile2:
Those are the Hard Krome 3" Big Straights. You have a couple of choices: the stock baffles or the SmartPartz Quiet Core baffles. The SP baffles are supposed to be installed while leaving the stock baffles in, so I don't know how well they'll work/sound without the stock baffles in.
Also, call Phat Performance Parts first to be sure they actually have them in stock before your order. Some people have complained about ordering from them and then getting notified weeks later that the parts weren't in stock.
http://www.phatperformanceparts.com/ProductDetails.asp?ProductCode=HK-BAFFLES&CartID=
http://www.smartpartz.com/SPZHK300SP.html
:thumbup: HK 3" Big Straights. I had those on my bike for a while. Looked great but stuck out too far, you can scrape easy entering or exiting a steep grade driveway and be careful backing/parking into curb- that's why the tips are replaceable. They had too much snap in the sound for me, and probably have a lot of decal pop without baffles. Good Luck with your search.
As mentioned they are HK 3" Long Straights. As far as I know, you can still get the Smartz 4-1/2" baffles from J & P Cycles. I added them to mine to tone it down a bit and give a little back pressure. The HK end caps only have the 1 fastener to hold them in place. The end caps are also maybe $75-$80 EA. -if- you can find them. I drilled 2 smaller bolt holes and used acorn nuts on the bolts to really secure them in place. What is your location? I found a great steal of a deal on a brand new set of HK 3" a couple years ago, and I have a set of perfectly good functional HK 3" pipes with caps, although they are somewhat blemished with nicks from backing into curbs, scratches and minor abrasions. I have them already boxed up for shipping. All I am asking is YOU pay the shipping and maybe $20 for my time and effort. Depending what part of the country it might cost you $100. Better than $800 for a brand new set if you can find them. PM me here for information.
Yes, they do have a lot of decal pop which I do not like. I like the sound of them if it werent for that. I assume (big assumption) that the baffles would ride that or at very least, tone that down a ton? Am I correct that the backpressure loss amount from the baffle removal doesnt hurt the motor, yet does it no favors either?
I did not see your latest post Prtmkr. Less torque on bottom end without back pressure.
I have random decell pops, but contained. Above 3500 feet I have a popcorn popper.
Take a look at Prockery's thread. Looks like a simple project.
Prockey did a sink strainer and a cross to hold a washer in place. He did not drill any holes as far as I know.
DIY is a good thing. Two reducers with small ends welded or one with a smaller small end to overlay and attach your
baffle. You could use multiple sink strainers.
My HK has numbers by the mounting tab/boss.
One bolt held the original baffle in.
I posted on Gearbanger's thread earlier today. I am Baffled!
Discussion Starter #9
So I called Double D Hard Krome today and bought a set of stock baffles for them. They just asked for part number which I gave them and asked if I wanted quiet ones or stock ones. They were 39 bucks each plus shipping. They do sell the infamous tips also that get banged up and they said those were also 39 each plus shipping. A big thanks to you guys for identifying my exhaust so I knew where to look for replacements. Thanks again to ranger for trying to get the best cost on getting me replacements. You guy are alright 😊 Mucho thanks
Wow. $39 on the tips is a lot better than they sold them to me for $75 ea. Must be clearance-ing them out! Get 'em while they're HOT!
Discussion Starter #11
Received the baffles today/afternoon. So......they are in there. Using some wood blocks, and a dead blow, was able to get them within roughly 1/2" where they needed to be. Then they just would not go any further. I do not believe they will come out either!! However, was unable to get the screws in to hold them. What harm could this cause? I figured if I couldnt get them in any farther I would prob not have to worry about them coming out. Put the tips back on and am excited to give her a go tomorrow!
You should be fine...even if they come loose, they can't get past the tips anyway.
Cannon swabbing tools to remove carbon and some lube to reduce friction!!!
A smoker for a short time...
If you hear them rattle, you get another chance to bolt them down!
Hans, I think I have the same pipes you have. They came with the bike and have no name on them, but they look like yours.
Jackk, a few inches rear of the mounting boss is a bracket(welded band) that holds pipe and heat shield together,
my HK has stamped model numbers.
Discussion Starter #16
That is the same spot as the 3" pipes. The part number I believe starts with either a 035-"XXXX" or 45-"XXXX". It is stamped on the pipe as Hans stated.
1 - 16 of 16 Posts
