Audio question(s)
1K views 2 replies 3 participants last post by  Hans&Feet
#1 ·
I will type loud for you cats that have a LOUD RADIO and are now hearing impaired!
Bike: 02 VTX1800R with Unidentified Batwing. ( maybe a reckless ) quad speakers.
Radio: AQ-MP-5BT By AquticAV
Specs on Head unit:
SPECIFICATIONS DIMENSIONS
Supported Media: Bluetooth/MP3/AM/FM
Fits devices up to the size of Samsung Galaxy Note
and iPhone 6 Plus.But NOT MY Galaxy 9 S:crying:
Device Charging: via USB
Display: Dot Matrix LCD
Detachable Faceplate: Yes
Inputs: Bluetooth, 1x 3.5mm stereo jack, 1x stereo pair RCA
Outputs: 1x pair RCA Pre-out (2V)
AM/FM Tuner: 18x FM, 12x AM pre-set memory. US/Euro frequencies
Power (max): 4x 45W (4 Ohms), 4x 72W (2 Ohms)
Amplifier Type: Class A/B (2 Ohm stable)
Output Voltage: 9.6V - 14.4V DC
Current Draw: 7A (max) / 6mA (standby)
Waterproof: Yes - IP55
UV Protection: 500hrs stable
Salt/Fog Protection: 500hrs stable
Certifications: CE, RoHS, WEE, FCC
Fascia Material: ABS
Chassis Material: ZAM Coated
Accessories: AQ-WR-5F Remote Control (sold separately)
Additional Features: Removable Faceplate
Bass/Treble, Balance/Fader, Loudness
Stainless Steel mounting hardware
Speakers: 4X Boss Nx524 300 watts ( yeah sure they are!):roll:
Full Range 5.25" 4-way Speaker Pair
300 Watts MAX 150 Watts RMS Power Handling per Pair
85 Hz to 20 kHz Frequency Response and 90dB Sensitivity
Poly Injection Woofer Cone and Rubber Surround
2 Tweeters and 1.25 inch Mylar Cone Midrange Per Speaker
Sold in Pairs
Detailed Description
(Manufacturer # NX524 )
Specifications
General Specs
SPEAKER TYPE Full Range
CONFIGURATION 4-way
Physical Specifics
WOOFER SIZE 5.25"
TWEETER SIZE(S) 0.5" , 0.5"
MOUNTING DEPTH 2.25"
MIDRANGE SIZE 1.25"
SUPPLIED GRILL ✓
Performance Specs
PEAK POWER HANDLING 300 Watts Which is B.S :agree:
SYSTEM SENSITIVITY (1W/1M) 90 dB
SYSTEM IMPEDANCE 4Ω
SYSTEM FREQUENCY RESPONSE 85 Hz to 20 kHz, ±1 dB
Amp: NONE
ISSUE I would like to improve
The radio sounds great-ish up to 3/4 vol. with some bass added but over this, it clips unless you turn the bass down to neg 3. My speakers are 4ohm radio gives me 45 watts at 4ohm per channel I can increase this with 2 ohms to 72 watts per channel. The speakers I have are fair but lack strong bass this I know. What is first? Better speakers or will I need speakers and amp. If so which amp can be trusted to perform well? When I was a kid we had a hand full of components to choose from. We knew the good bad and gnarly. Now there is so much on the market im lost... I dont want to rattle glass but do want to hear John Entwistle, Flea, Jack bruces bass licks while riding
Thanks Joe
See less See more
#2 · (Edited)
no unit will sound good over 3/4 volume... THD goes up quickly over 60 percent.
better speakers... then if needed a larger amp...
my opinion.
I no longer do sound systems...
I did custom for motorcycles from 1970's - late 1980's.
no money in it..
#3 ·
Crutchfield showed 24 watts RMS x 4 = 96 watts. 14.4 volts x 7 amps = 100.8 watts.
95% efficiency. ??? Fused at 7a, probably pulling 5amps.
Speakers - last I checked a few years ago I could hear to 6Khz. I do not need tweeters!
Do you have good size wires on the power lesds?? Wired through a relay directly to the battery??
