1 - 3 of 3 Posts
I have a problem with my audiovox cruise control.......it wont work any more! all the electrical connections are fine. there is oil in the vacuum line, which may be the issue. anyone else have this issue, and what is the fix. I assume I will have to change all the affected vacuum lines, but what about the main unit..any suggestions?
Hope you have better luck here, Jeff.
Yep, most likely vacuum plumbing, the oil in the line is a good clue. I have a batwing so installed a vacuum gage so that I can monitor the vacuum. What are you using for a vacuum chamber?
1 - 3 of 3 Posts
