Im an authorized Audiovox dealer. I have installed many. Great system, and at that price, ya cant lose.
re: audioVox MA200...
Thanks for the reply. Bought it and now installing.... a really compact unit.
The only wrinkle is in the installation instructions....they instruct to "wire the orange wire into the ignition", without further explanation. I assume that I can tap the right hand fuse block and tap into the circuit labelled "Starter/Ign", 10A?
And, I suppose there is no way to pulse an LED off this thing when it is armed?
Havent done my VTX..I hate alarms...LOL. No LED output on them,you CAN buy a Varad scanner, that connects to the negative output wire....But remember, bikes are usually outside during the day, and ya cant see that LED light, unlike in a car, shaded from the sun by the roof.
Gotter Done!
Installed the alarm. Seems to work ok. I just tapped into the fuse block, and got the 'start/ign' line. Hid the siren/brain under the tank.
I did NOT wire in a relay for lights/horn/starter disconnect. I will test for a while before trying that (if I need it).
The 'shock' and 'tlt' sensor seems to work pretty good on the most sensitive settings.
Remotes work well and have plenty of range.
More later.
