A few weeks ago, I bought an '06 1300C with about 35k miles. If I could go back a few weeks and do it over again, I probably would not have bought this bike...for several reasons.
First and foremost, it's not running right. On the plus side, it does start. However, it needs the choke to run. I started it today to add some sea foam into the tank and get it into the system. It starts with the choke and pretty much needs the choke to run. I can close the choke to halfway and it still runs. But, if I close the choke, then the bike just shuts off. I was told not to run the bike too long with the choke because it will foul up the plugs, so I only ran it for a few minutes.
I could have sworn I noticed a small puff of black smoke when I started the bike or maybe it was when I turned the throttle. Either way, I think I did see that. From what I read, a puff of black smoke means it's running rich...but, doesn't that contradict what everyone says about these bikes in that they run lean?
What are my next steps? What would you do to get this bike running tip top? The bike does have the V & H Big Shots. I have no idea if they PO rejetted the bike after the pipes. I can assume he didn't. Either way, I'm guessing the pipes (as good as they sound) are not helping the way the bike is running. Is the next logical step to tear down the carb and do a rebuild on it? I am guessing a new 58 main jet might help (if that wasn't done already). What are your thoughts?
I might very well sell the bike, but I want to make sure it's running awesome before I sell it. I think I was pretty dumb in buying a bike that I literally saw run really cold blooded. That was my mistake and, as I said, one that I regret. Please help me fix this...Whether I keep or sell the bike, I need it to run great.
