1 - 3 of 3 Posts
I keep blowing the fuse for the tail lights and odometer as soon as the switch is turned on. I know it's not a lot of info, but any suggestions as to what it may be or where to start to check?
Thanks!
EDIT: Some things a search has revealed (which I guess I could have done first) is: Bad ground on light bar, blown licence plate bulb
trace the brown wire from behind right side cover in the rubber boot along the frame rail.
you can unplug there and see if it blows fuse if it doesn't then the problem is aft of the plug if it blows then it is forward of the plug this narrows down some.
1 - 3 of 3 Posts
