1 - 9 of 9 Posts
X'ers,
When I bought the X last summer, I immediately put in a Xenon bulb. I had done this with my Sabre as well. With the Sabre, it one time blew a fuse and the whole light went out. I just replaced the fuse.
Last night, I went to ride home and the high beam blew when I started her up. Low beam still works. I haven't had time to take a good look yet but was wondering if anyone had a similar experience and idea as to what happened.
When I installed, I was careful not to touch the glass. Is there a separate fuse for just high beam? I don't exactly remember the specs of the bulb, but I am sure some would say I need a voltage doohickey. Is it common for either the high or low beams to burn out while the other still works?
Appreciate any help you can give.
Ptackley
my stock one is blown out after only about 4k. what a shock when you go to use the high beam on a back road and everything goes out. yikes! i really need to replace that tonite!
Yes it was a shock when it blew! Oh well, sounds like it is to be expected. Thanks guys for your input. Off to go get a new light bulb!
PTackley
Chicago-Spike said:
Go to the Sylvania Silver Star, much better light than the stock(same wattage) 8)
Spike,
Where can you buy this bulb?
Ptackley
1 - 9 of 9 Posts
