1 - 13 of 13 Posts
Bought used with V&K pipes, Cobra passenger back rest & bar, Cobra fuel manager, Memphis Shades windshield, Honda MP3 stereo & River Road bags -- 2134 miles.
Added Jardine grips, Fatty Freeway bar, Rivco rear floor boards & Kury Dually Iso pegs first month.
Discussion Starter #2
Sept 19, 2009
Added WOLO Bad Boy chrome air horn in stock horn position. Made custom bracket from 1/8 aluminum plate. extended stock horn wiring to side cover, mounted relay & 20a fuse under cover. ran 18 ga wire & ground wire back down to horn. All new wires are in wire loom & hidden.
Sept 26, 2005 3088
Replaced filter & changed oil Mobil 1 full syn 10w40.
REMOVED 3 oz of oil from 1 gal (4 qts) & poured remainder (3.9 qts) in crank case.
Marked dip stick with full level leaning on side stand.
Added spacers to air filter cover for better breathing "Opee Mod"!
Discussion Starter #4
Future Mods 10-5-09 3238mi
Not in any order: (incompelete)
(Buff wheels)
(Pin stripping)
(Hard bags)
Replaced shock bushings (4) w/08 Honda 1800f lower bushings @ 8655 mi
Ultimate Lowerider 3 piece seat 7/28/11
SDC Diamond Star Headlight modulator 3/1/10
SDC Backoff brake modulator 3/1/10
SDC Tri-Star turn signal to brake light converter 3/1/10
MTC clutch springs 1/28/10 @ 4265 mi
Webslinger custom "Flame" speedo face plate 1/28/10 @ 4265 mi
Garage door opener 2/2/10
Driving lights 2/2/10
Ground fix Checked 2/24/11 @ 7719 mi
Pair Valve mod 2/24/11 @ 7719 mi
Signal mirrors 3/3/11 @ 7719 mi
Checked ball ends on shifter shaft 3/8/11 @ 7719 mi
Lubed shifter pivot pin 3/8/11 @ 7719 mi
Progressive fork springs 3/9/11 @ 7719 mi
Replaced front brake pads & tire w/ME880 & 2oz dynabeads 3/18/11 @ 7719 mi
Went to the "Darkside" with a Yokohama Avid Touring S P205/60R16 w/3oz dynabeads 3/18/11 @ 7719 mi (ck'd rear pads (1/2)
Installed K&N air filter 3/13/12 10873 mi
Changed Final fluid w/Mobile1 full syn hypoid 75w90 12026 mi
Power distribution block & ground buss
Added a 6 circuit (relay switched) power distrbution block behind left side cover, mounted (velcro) to the tool box door. Used NAPA fuse block part# 720224. Also added a common ground buss to top of battery cover.
9 April 2011
Changed oil & filter 7800 miles Rotella T 5w40 full syn blue bottle.
Bob, I got Wolo chrome trumpets last fall and am going to put them on shortly but can't see where to mount them easily. Do you have a close up picture of your mount? Thanks a ton.
Discussion Starter #8
Hope these help.
Discussion Starter #9
Changed oil & filter 11683 miles Mobile 1 full syn. Fram PH6017A filter.
Discussion Starter #10
19 July 2013
Changed oil & filter 13613 mi.
Mobile 1 full syn 10w40
Mobile 1 M1-110 filter
Discussion Starter #11
7/2/2015
Changed oil & filter Mobile 1 10w40 @13993 miles 2014 (just found my note 7/17/15) :banghead:
Replaced front tire with Shinko TourMaster 230 @ 15292 miles. Last tire was a ME880 & 2oz dynabeads 3/18/11 @ 7719 mi. Lasted 7573 miles
Changed oil & filter Rotella T 5w40 full syn @15292 miles
Discussion Starter #12
Changed oil & filter Mobile 1 5T M/C full synthetic oil 10w40 K & N SN-204 filter 17715 miles
Discussion Starter #13
19796 miles
Installed new Yokohama P205/60R16 91T rear with 14oz of Ride-On
Changed coolant Prestone 50/50
1 - 13 of 13 Posts
