1 - 9 of 9 Posts
I have a strange problem with my brake light and I have noticed this since several years now.
When actvated by pulling the right handle I get a very bright light but when using te brake pedal the light is significantly less bright.
When I short the connector that leads to the brake pedal switch the problem stays the same so it is not caused bij a bad switch.
Any thoughts?
Any thoughts?
There are two possibilities here. First, the source wire coming into the brake switch may be the problem. Suggest taking a jumper wire from a known source (battery) and connect to the lead going to the brake light to see if there's a difference. If that doesn't change anything then you know its the wire from the switch to the brake light has a fault. Whichever it turns out to be, follow the color and look for a pinched wire or a dirty or loose plug connector.
Reactions: rangers4u
White/Green is the +12v source from the fuse to the brake switches.
Green/Yellow from switches to bullet connections to Brake light.
Does Honda splice on a wire or wires in the cable harness to make a circuit??? Probably...
Check for voltage drop. Verify your rear switch adjustment allows for a good contact.
Many years ago I noticed a problem with my brake light.
Rear switch worked correctly, illuminated immediately.
The front brake switch had a delayed start.
What really got my attention was when the lamps began lighting up and the leds lit up later.
Normally Leds light up immediately. The front switch had a dark spot on it.
This developed after a long ride in the rain. I cleaned the switch contacts and then
the leds and lamps worked correctly.
Thanks guys. I will check this out later since for the moment the connector is hidden behind a lower radiator cover
Update:
I found the cause, a defective hydrolic brake light switch of my aftermarket forward controls, installed in 2005.
I replaced it and everything is OK now.
Automotive tire Wood Asphalt Terrestrial animal Horseshoe
Defective switch
Data transfer cable Font Cable Circle Event
New switch
Brake fluid got to the switch side possibly or the weather got to it..
Good to see problem resolved!
Ford vehicles used a hydraulic brake switch many years ago.
Anyone looking to "increase" the brightness of their brake lights (or turn signals) would do well. to buff those bad boys out with a wheel.
1 - 9 of 9 Posts
