There has to be a proven method of getting the baffles out. Please help! Tell me how you did it!
My 1300C has great sounding Bub Jug Huggers but I wanted to take it down a notch for my neighbors sake so I ordered the Stealth baffles. These pipes have been on the bike for a while so they have been thru several heat cycles and have carbon built up on the inside.
Well yesterday I set out to swap out the stock baffles with the Stealth bafflles. Removing the tips went ok. Removing the short bent pipe not so easy. The first one I got off while it was still on the bike. The allen heads of the screws on the second pipe started to strip so off came the pipe and onto the bench where I had to drill and easy-out the screws. With all the screws out and the pipe seated in my bench vise (chrome heat shield removed as well) a made a long hook from some 1/4" round steel bar and began to attempt to hook the baffle and use a hammer to bang it ou of there. I could only get it to move about 3/4" in all. I used heat on the outside to try and expand the external pipe. I also tried heat on the inside. By now I was extemely frustrated because what I thought might take 2-3 hrs at most now has taken all day and the baffles are still in! I should mention that I do not have oxy-acetylene for the heat... I used a plumbers MAP gas torch. This got the pipes locally red hot but I am sure that if I had oxy-acetylene I could have got a more uniform hot spot all around.
Calling all experts... What is the secret!!! :yikes:
