You undo the three screws in the front ring of the housing. Then you can pull off the ring, exposing the bulb. pull it out towards you and pull the rubber gasket back... it's on there with a wire guide/lock thing (just look at it and you'll understand). Then you can pull the bulb out and replace it with the bulb of your choice. I'm sure someone will let you know if I missed a step, but you don't have to totally remove the headlight if that's what you were wondering.
Two screws under the Headlight visor, #22
one screw below the headlight
then pull the chrome rim (#13) and light assembly (#5) out as a unit leaving the main housing intact.(#12)
Pull wire connector off Halogen bulb,
remove rubber seal
remove and replace bulb, (#11)
install reverse order
Which bulb are you talking about?
For the headlight - you need only remove the two screws at 10 and 2 o'clock. The bottom one can stay in.
For the turns - there is a screw at the bottom - remove that and you should be able to pop the lens off. There is a barb at the top so pinch down on the top of the lens.
the headlight.
