last attempt got sidetracked so I will try again for asking about hose connections for the post-pair-removal process for a 1300
the slow roll is fine and it goes high in rpm without stalling but if I quickly twist, it stutters and stalls
this obviously goes to the gas tank vent on bottom and routes to outside.
these two apparently still go directly to the fuel petcock valve
only the one smaller of the two hoses for the back of the air intake are still attached, the larger was removed, according to directions along with the other two hoses attached to the evap canister under the rear wheel.
here I have a smaller vacuum line from the bypass valves up front which T’s into the petcock valve and the bottom of the carb. It is unknown currently if one of these or more need to be capped off, or resized to fit the rear center vacuum tip on the inner portion of the carb. There is a larger, apparently 3/8 inch or so on the rear portion of the carb that is not known what to do with.
I have Tappers information but it is only of direct help for the 1800 model….mine is the 1300, so no plugs like the larger FI model, not some of the images are directly related. Secondary air system removal is not for my bike as it stands so no big deal.
As it stands I am absolutely blank on the following:
Both inlets on the carb, one is 3/8 and the other is not quite a 1/8 little larger, 3/16 perhaps.
The lines from the front under the frame neck that led to a bunch of other valves and vacuum connects into the petcock and front bottom portion of the carb.
Basically I would find pictures of the following areas very useful either from a non-CA model 1300 that has had the connections made fully. Or is there is a Tapper-like write up for the 1300 CA model.
I found the following very useful and will try some more tomorrow but its always good to ask for more info before I start again.
http://www.vtxoa.com/forums/viewtopic.p ... pair+valve
thanks
thanks
