I went on a 180 mile ride on saturday scooting around all of the thunderstorms from winter garden to Ocala national forest and back. after I got home I noticed I had a nail in my rear tire. I only have 1000 miles on it. I want to know if someone will patch or plug it?
hate to have to spend $300. for a new tire to be installed.
I have confidence in a plug or patch and I am not wanting to start a debate.
thanks,
John
Hi John,
sorry to hear about getting a nail so soon. I picked up a drywall screw in the center of the tread of my rear tire not long after getting my bike. I put a temporary plug in it and made some phone calls. I found a yamaha dealer in Zephyrhills that put a perma-plug in it. Lasted about 8000 miles till I replaced the tire from wear. Never had a problem.
Russ
Guess I should check mine too! All in all, a great ride as usual!
John, if the nail is close to the center of the tire, plugging shouldn't be a problem. You can call Seth at Motorcycles of Apopka, I'm sure they could do it.
Yes, Kevin can!!
He plugged my darkside tire. Right after I had it, I picked up a nail and
he plugged it.
You can pick up a plug kit at any car parts place. The best ones are the ones with mushrooms shaped plugs, but they are a little hard to find. Maybe Cycle gear or someone like that would have it. It isn't a tough job. Works fine in rear tires as long as it isn't in the sidewall.
Motorcycle Clinic in Kissimmee did my Bridgestone Battleax. Wherever you go, make sure it's done right. I have a Stop 'N Go kit with mushroom plugs and I've had to use it way too many times. Most have held up well, but it's considered a temporary fix until you can get it patched and plugged from the INSIDE of the tire - or replace the tire. I had an Avon that Motorcycle Clinic wouldn't repair because the hole was too far toward the sidewall.
Bob
Mad Hatter
thanks,
John
No Problem John!! As Per out Phone conversation, Tomorrow Night!!
Discussion Starter · #8 ·
Thanks guys, I was able to plug it myself and so far it is holding air.
it is only 1 1/2" from the sidewall so I think I need a new tire.
Now I have to make a decision. CT or MC ?
John
