monkeyboy said:
Where should I adjust? I also have a loose throttle. Seems like it has too much slack when idle..you can see it on the carb loosen up. I'm not sure where to make the right adjustment there either. Thanks for the help.
You can make minor adjustments at the clutch top adjustment nut near the lever. Large adjustments are made at the bottom adjuster above the left engine cover. You should have about 1/4" of freeplay on the clutch.
The throttle also has two adjustment points, on on the upper cable for little stuff, and at the carb end for the bigger stuff. You need about 1/8" of freeplay on the throttle.
All the adjustment nuts work the same - loosen the locknut, adjust, tighten the locknut. It's very easy. All of this info should be in your owners manual as well.
