steingang2 said:
My clutch has about 1/2 to 3/4 of an inch of lose play when released. How much lose play in the clutch is normal? How do you reduce it? have an '05 R.
that's about what i have.....think that's about where it should be
Between the perch and the lever should be no wider than the thickness of two nickles stacked together. You can adjust the cable either at the engine side or the lever side. Both ends have a screw adjustment.
so like 4-6 mm??? :oops:
um yeah I don't think i've used a standard wrench or socket in over a month! Metric is the wave of the future!
Ok Ok i'll stick with two nickles!
