It has been at least 2/3 weeks since I've ridden (Cold Arkansas) and today at lunch I decided to trade the truck for the bike. Anyhow I noticed right away there was not much clutch handle but thought well something may have stuck and will free up with a small ride (Stupid me). I ended up putting it back in the garage and thought I don't want to get to far away from home and have something happen to where I have to load it on a trailer (not a harley). Also noticed when I pulled it back in the garage I couldn't shift from 1st to neutral so I killed the engine and then it shifted.
Any thoughts anyone? The bike has around 19k miles and I have flushed and filled the clutch system about 1.5 years ago.
I'll bet if you bleed it you'll get just a little bit of air. This is a strange anomaly, but I found the same thing on a riding buddies bike a few months ago. We bled it and it's fine now :dontknow:
Thanks Jon, same thing Dhealy50 said to do. Didn't have a chance to do it after work since I am trying to get the new HiDef TV and satellite all up and running the way I want. Will probably do it Thursday.
Jon that fixed it. Took me longer to take the cover off than it did to fix it. Pumped up the mightvac and cracked the bleeder. Remove not more than a thimble of fluid and presto I had clutch again. Thanks. Really strange thing.
Same thing Happened to SKAMMERS bike on the Miss Board and he has the MTC clutch. No leaks but had no clutch.
Bare Blead the system and it never had a problem since.
