1 - 1 of 1 Posts
Clutch lever, clutch switch with Kury levers mod to allow start in gear with kickstand UP.
#10 · Mar 28, 2018 (Edited)
Background makes it difficult to see the nub in the circle.
prkuehn photo of the mod and his text.
Jeff,
The below drawing shows the metal piece on the clutch lever that manipulates the switch when the clutch lever is pulled to the grip.
It is very simple to confirm if your switch is working correctly. Put a multimeter on it and you should see an open circuit with the lever all the way out. You should also see a closed circuit with the lever pulled all the way to the grip. If you experience those two results, you need to start tracing wire through the rest of the circuit.
1 - 1 of 1 Posts
