1 - 2 of 2 Posts
Replace my springs, bead blast the steel plates, fiber plates look good, rode good for about 200 miles and starting to slip again. Heard of MTC clutch. Where do I get them from online? Or is there something else I can use? Not using syn. oil.
Could have to do with what type Castrol you did use before. Once the moly additives soak into the fiberous friction plates they are done. The MTC is a harder shifting set-up for the X. If you have added a lot of torque&hp that is the way to go. The Barnett set-up is very good, comes with both steels and friction plates(MTC only has friction). 8)
http://www.hondadirectlineusa.com/vtx/b ... =352078400
1 - 2 of 2 Posts
