1 - 10 of 10 Posts
Hey,
I'm thinking of getting the Cobra Fatty Highway bars for my 1300S, but I keep hearing that there's clearance problems with the brake pedal. If any of you have these, can you let me know if you have this problem as well. I have a Pro R hypercharger, so I already have use the outside half of the pedal, just want to make sure I don't dump $180 on these and then have to turn around and sell them due to the clearance issue.
dont know about that on the 1300 but i got them on my 1800 with no problem i have a friend with them on their 1300 i will check to see if they have had any problem and get back with you
workman205
I have had my fatty's on for about a week and a half and have not had a problem with them.
No clearance issues here, just a bit of a PITA getting the crossmember mounted in by myself. You need a really small hand to get the screws started, after that piece of cake. They look great too.
I only have a problem when I'm wearing my steel toe boots. 13wides. Otherwise I love them. If you make the tech session at Marks you can try mine out before you buy !!!
I also have these bars,and really like em..No clearance issues..The bolts on the top are a little difficult to get started,but not that big a deal..
I have the Cobra Fatties on my '06 1300C. Brake side is fine with clearance, my problem is with the shifter side with a tight squeeze only when I wear my Milwaukee boots where the toe is taller than my other riding boots. Other than this, the fatties are fine!
Discussion Starter · #8 ·
fatties
For all you guys with C's, I do appreciate the input. Unfortunately, its apples and oranges since you guys have forwards, and us retro/s guys have the floorboards, which I'm sure makes a huge difference.
Hopefully, I'll run into a few R/S guys at the tech session and see if it will be an issue for me.
But again, thanks to all those that have replied...see you at the session.
Hey Greg, if/when you get them, I will gladley help you install them. I live close as you know, and my only cost is beer :D .
Discussion Starter · #10 ·
thanks
Thanks brother,
I'll let u know if I end up getting them.
1 - 10 of 10 Posts
