1 - 15 of 15 Posts
The VTX 1800C muffler is actually well designed to accommodate Honda's hp and tq output. Removing the Catalytic converter from the front of the muffler actually makes the muffler free flowing and afterwards there is a noticeable increase in throttle response and improved acceleration. The volume of the stock sound increases without a crappy sound like I have heard so many state their disappointment in the sound after drilling holes in the back of the muffler. Drilling holes in the back of the muffler doesnt make it more free flowing as the restriction is up front in the cat.
Removing the cat is the only internal modification I did. The other modification was external and involved removing the exhaust tip and cutting the 2 tubes close to the end of the muffler, then reinstalling the exhaust tip. This increased the volume even more and the sound is really awesome at idle and throughout the rev range but never obnoxiously loud.
Getting the cat out takes the most time but the difference in power is seat of the pants noticeable. It will make you feel like the muffler was really stopped up beforehand. It is that noticeable.
If you have always favored the single crankpin sound like I have you will be very pleased with this twin crankpin sound. It really sounds that good....and even though the twin crankpin Honda will never sound like a Harley (that is what the VTX1300 sounds like) The VTX1800C with this mod has a powerful deep sound and definitely has that big block rumble that lets everyone know this 110 isn't fooling around.
If you do this mod I would like to hear your comments on the difference afterward..
Discussion Starter #2
The one pic is with most of the cat removed. I actually scraped the remaining pieces out before I installed the muffler. It is a good pic of the shower drain like plate behind the cat. I left the shower drain looking plate intact. Only removed the cat.
Most of the VTX owners can't do this mod at all, because they don't have cat. converter in their exhaust system originally. Only California and EU bikes have cat. converter, if I remember correctly.
That is interesting about only the CA models have the cat in the front of the muffler as the muffler I modded was another original Vtx1800c muffler that I found locally here in Oklahoma and the original one I took off my bike also had the cat. Have other owners had their original muffler off and looked to see if they have a cat or not in the front of the muffler?. I would like to see a pic of a muffler that does not have the cat to see what the internal difference looks like.
VTX1800C A muffler has a different part number than the VTX1800C AC model. The AC model also got the evap canister, and an O2 sensor in the pipe.
My bet is that the only difference in the muffler would be the cat.
I had removed the internals of two 1800C mufflers completely. Don't remeber having cat. converter inside, just the blocking plates and pipes. Didn't take pictures.
FYI
09/02/2003 - Torrance, Calif.
VTX means Performance First™, and nothing says performance like the stunning VTX1800C. Powered by an 1800cc engine, the VTX1800C combines street-rod styling with the biggest mass-produced V- twin engine available.
Features & Benefits
New for 2004
The VTX™1800C is available in these exciting new color schemes: Magenta Metallic, Candy Orange Flame, Titanium Flame, and Black.
Unique Features
Show-stopping street rod styling with beautiful satin-finish cast aluminum wheels.
Minimalist-design front and rear steel fenders complement the VTX's street-rod styling.
Dragster-style seat boasts a low, 27.3-inch seat height for flat-footed confidence during low-speed maneuvers
Semi-swept handlebar design provides a comfortable, upright riding position.
Handsome chromed two-into-one exhaust system produces a deep exhaust note.
Wide, low, 130/70R-18 radial front tire enhances street-rod styling and delivers superb handling.
Aggressive 180/70R-16 radial rear tire puts the engine's awesome power to the ground and provides exceptional traction.
Large, handsomely finished 4.5-gallon gas tank with aviation-style fuel cap offers extended cruising range.
ECU-controlled, closed-loop emission control system utilizes an air injection system and three-way exhaust catalyzer to simultaneously reduce emissions of hydrocarbons (HC), carbon monoxide (CO), and oxides of nitrogen (NOx). 49-state model exceeds California Air Resources Board (CARB) 2004 emissions standards and California model exceeds CARB 2008 standards.
Im pretty sure at least the later models all had cats. The California models have an O2 sensor and a smog pump that is the muffler difference.
The newer (2006 and later) 1800C models have different mufflers, than the before 2006 models. Don't know what the difference is, but the later mufflers are significantly more expensive. What is the reason behind the price difference? Maybe the cat? BTW, checking part numbers, I see, Cali. and non Cali. mufflers are always different for some reason.
I don't know, if my 2006 1800F has cat, in the mufflers, but my 2003 VTX is definetly the "faster" and more responsive bike and that doesn't have cat (and any kind of back pressure :)) for sure.
The shower drain part will help with decel popping and give a little back pressure, good choice. I had my bike on the dyno after the cat removal (straight through no obstruction) with and without a baffle and packing no horse power change it just moved in the rev range. I now run with baffle and no packing seems to be where I like the sound and feels the best power and torque wise.
Guess, I don't remember correctly. It was more tjan 10 years ago... But muffler part numbers are different for older and newer models anyway.
Discussion Starter #15
I put about 100 miles on my bike yesterday. Just a great sound at idle and when you get on it. It is quietest at steady speed but you can still hear it. Great burble on decel and when you shift. Great throttle response. My bike only has the pair valve. no smog pump or 02 sensor bung. The cat must be the diffeeence in power between the first models and later years. They always say the first model year is the fastest. Mine is a 2006.
1 - 15 of 15 Posts
