The last couple times I have ridden my 2003 1800c I have occasionally smelled coolant. Extremely light smell...like the hint of the ghost of a wiff lol. I will smell it very rarely when I'm stopped
The coolant reservoir appears to have the correct amount of coolant in it. There is never any leaked coolant on the garage floor, I have never found any coolant on the engine or coolant hoses etc.
At this point my best guess is it is leaking very slightly from the crossover tube under pressure and burning off on the hot engine.
I had always intended to remove the gas tank this off season and flush and change the coolant. Now with the addition of the coolant smell my plan has changed to one of inspecting/refurbishing the coolant system vs just flushing and filling.
I have read in past threads that the coolant crossover tube between the cylinders and it's associated O-rings can be a source of potential issues.
I'm planning on changing the O-rings.
I figured I would change the radiator cap since i'd be surprised if it wasn't the original.
I'll go through and check the tightness of all the hose clamps in the system.
I have a coolant system pressure tester and plan on testing the system.
My question is:
In light of the info I've given and the steps I plan on taking does anyone have any recommendations of weak spots in the system I should check, potential failure points that others have encountered, fixes that have worked for people with similar symptoms in the past etc etc...
I am traveling for the next two weeks and would like to order any parts I might need and gain as much insight into the system as I can so when i get back I can ideally break the bike down, fix the issue and have it back up and running in short order.
My question is:
