1 - 3 of 3 Posts
How important is it to have coolant all the way to fill mark in reservoir,,,,,mine is even at lowest mark,,,,,,geting ready for a several mile ride,,,,,,,?
I don't think the earth would stop rotating...but while out on this "several mile ride" you discover it is now below the low level mark...whatcha going to do then? I don't think it is anything to worry about (unless the reservoir was empty, signaling that I don't know what the fluid level in the radiator is at)...but I would add some distilled water (won't take very much).
More importantly though...I'd check for leaks...my reservoir level has never changed.
Bull
Do Not Trust The Overflow Resevoir!!!!!
I did and it ended up screwing me over.....My temp light came on during a trip and that is the worst feeling. After trouble shooting and diving into everything, I removed the tank and drained the radiator to do a flush and fill and I was LOW on coolant, however the resevior was full. Once I filled up the radiator, light went off and haven't seen it since.
Check the fluid at the radiator cap, not the overflow.
1 - 3 of 3 Posts
