Hi guys, when I ride in slow moving traffic (which happens quite often), my reserve coolant tank seems to run low gradually. There are no coolant leaks that I can physically see.
Is this normal for the X to be burning up coolant during slow, stop and go city traffic for about 1 to 2 hours? Anything else I can check up on?
Cheers!
Cheers!
after the bike cools down or it sets for a while does the coolant level come back up to where it should be, Have you had to add any coolant
Then you're leaking it somewhere. Tighten up the hose clamps, especially the 2 between the cylinders. They losen up after a while
Welcome to the board!
Bookmark or save to your favorites folder, these websites, http://tech.vtxoa.com This is the VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://www.vtx1300tips.com/ another fellow VTX Riders site.
There is also a helpful red Search icon at the top of every page(not the Google search)
Search Query section
Search for Key Words;__________________________
Below that click on the "Search for All Terms" button, effectively unchecking the default selection of "Search for any terms or use query as entered"
Search Options section
Now that you have a list of threads you've searched for, do not just click on the thread you want to read. Instead RIGHT click on the thread and select "Open in New Window" This will pop up a new window with that thread in it, leaving your searched list intact for you to go back to.
Also, update your Profile to include where you live and what type X you have to your Signature line. I.E. 1300/1800/C/F/N/R/S.
You may have a very small leak; the coolant is boiling off as it leaks so you don't see it. Ride it to operating temperature and park it somewhere out of the wind. Sniff around it and see if you smell that sweet coolant odor. As suggested, check all clamps.
