I purchased a used bike and saw the cooling fan come on during the initial hour ride. Since then I have not had a chance to ride. I let it idle for 20 minutes yesterday and it didn’t come on. Any suggestions please? Maybe just not hot enough? The idiot light stayed off. Wish it had a temp gauge. Thanks
Check your coolant levels...I cant speak for all...but my fan has only come on a hand full of times in 14 years and that was hot,hot weather in stop and go....Good luck
Coolant level has to be checked at the thermostat housing under the tank.
Remove seat, remove rear tank bolt so you can tilt it up.
There is a radiator cap that has to be removed on the top of the thermostat housing..
Questions should go to the "1300 Riders board".
Maintenance and Accessory is for your oil changes, air filter(maintenance) or accessories you add to your ride.
