sometimes when you change your airbox you may have to reroute your crankcase breather
so, not knowing where this is located/what it does, can someone help clarify?
As long as your air intake system is stock you do NOT need that filter, because the PCV vent hose now runs into the back side of the filter housing from the front head. Now, if you ever decide to vent the PCV to "atmosphere" then you would install that filter on the end of the hose. Taz
so say i put on the P4, is this now needed?
No. The P4 has all the connections of the stock breather.
