OK, I made the rounds of Tire Rack, Sears, Discount tire and Goodyear today and I really do like the Goodyear Eagle F1. But the tire is only available as a 205-55-16. Does that recreate any fitting problems as compared to a 205-60-16? Goodyear also has tritread in a 205-60-16. I also found a local shop that will remove the old tire from the bike and remount, spin balance and install the new tire on the bike for $35.00. I need your opinion on as to what fits and what hits. oh, both tires recommend at least a 5.5" rim width.
Thanks for your help.
Dray
The 55 is a little shorter tire and will make your speedo show you are running faster than you really are. I ran the 55 in a Falken when I first went to the darkside. Then I switched to the Triple Tread in a 60, The 60 is a softer riding tire and they both fit the same in rim.
I run the Goodyear TT 60 also. Did a little grinding under the fender just as a precaution. Have never hit bottom, not even when 2-up. Had to let the air pressure down to about 10 psi to get the wheel installed, but was no big deal. Put a little soapy water on the sides of the tire and it slid into place easily.
I don't think you'll be disappointed with the 60, especially if you want your speedo to be close to normal. I have just about 2,400 miles on it and it looks like new.
I've got 5k on mine 205/65r16 MHE and love it. I did grind down the fender rails as a precation too. Easy to do.
I'm interested in the same thing 205 - 65 and worry about rubbing on the final drive shaft and or the right side of the swing arm. Any issues there???
Chuck,
No worries about rubbing in those areas. Seems common to have some slight rubbing on the inner rail. A wee bit of grinding seems to take care of it. :)
Going Dark
Thanks guys for all the input. I have pretty much decided that the Goodyear triple tread is the route to take. I'll let you know how it goes.
Thanks again.
Dray
