1 - 9 of 9 Posts
I did the Clayton Deep Mod yesterday and it sounds freakin awesome. I used a 12" 7/16 bit and drilled 4 holes in the shape of a smiley face.
I just got back from a 165 mile trip and no pops or backfires. I actually think I'm getting better gas mileage too. I haven't even hit reserve yet.
I'll see if I can get some pics up soon.
Best 15 bucks I've ever spent.
Poolmaster. I did the same mod last week. I now have alot of popping on Decel. Its funny how 2 of the same model bikes have 2 different results... O well, i guess i did something wrong.
Are you running stock jet? I've got a Dynojet Stage II kit with K&N filter. Maybe you should try that or adjust the A/F mixture.
Almost everyone has popping after doing this mod. Removing the PAIR valve is the solution. :wink:
+1 to metric mark.REMOVE PAIR VALVE!!!!!!!!
I'm glad I'm one of the lucky ones no popping or backfiring I did the standard mode just aft baffle. Took it out ran it up to 80 let off of it nothing. Even tried down shifting with happy results.
Here's pics of what I did. The left 3 holes are drilled into the baffle. The far right is just through the outer plate. I did the same on both pipes.
I did the Claton mod using the 7 15/32" holes, I like the sound, have put about 1000 miles since doing the mod, only once I noticed a pop on decel when the bike had not warmed up good yet. Mileage seemed to increase a little as well. Stock air box and filter.
I put 7, 1/2" holes in each pipe... Still got my Pair valve, and the stock jets... hasn't backfired or popped one time.
It is funny how the same model bikes will act differently.
1 - 9 of 9 Posts
