I recently did the valves on the 1800 and I think I did something wrong so I'm going to check them again this weekend and need a little advice. When I line up the mark on the crank should both sets of valves, meaning exhaust and intake have play in them at the same time? Or, since this is a 4-stroke engine , do I need to set the crank for one set and the turn it again for the other? Not trying to be confusing but the last time I did it when I would set the crank the exhaust valve would have play in it and the intakes would be tight. Turn it one more time and it's the opposite. The exhaust would be tight and the intakes would have play. Realizing that it's a 4 stoke engine on one compression it intakes and then the next it exhausts. Anyway that's how I did it last time and wanna make sure I'm not screwing something up. Just for informations sake , the first couple of times I had them checked I had it done at the dealer. Not confident that they were actually doing anything besides taking my money I had help from Hoss37 last spring. But since I'm old and senile I honestly don't remember if we set the crank just once for each head or we turned it twice for each head.
Or am not getting the crank at TDC?
By the way...it has that nice sewing machine sound but it' a really pissed off sewing maching. The valves are quite audible when the engine is running. I noticed on last weekends ride I could hear them while riding. Seems to run fine but I'm just not comfortable with it and want to check them again to be sure.
