1 - 2 of 2 Posts
when downloading a advanced or dual map from computer to pcIII do you download each fuel table separately? or do both fuel tables download at once ? I downloaded each fuel table separately from computer to pcIII i just wonder if i did it correctly any input would be helpful Thanks
Both cylinders will download in each map; you don't have to do them separately. Now, if you want you can use the "Map Compare" feature to look at the difference between each cylinder's maps or even with the individual cylinders of a second map.
1 - 2 of 2 Posts
