1 - 2 of 2 Posts
I am thinking about mounting some driving lights on my Kury ergo bars. Anyone have ideas about the best way to run wires for cosmetic sake? THe bars are not drilled where wire can be run thru the inside of the bars.
It sounds like you want to drill holes in your crashbar to run the wiring.
If you do, be sure to install a rubber grommet around each hole
that you drill so that the sharp edge of the metal will not
cut thru the insulation on the wires.
I would run the wires thru a length of split-loom or
heat shrink tubing to give the wiring a little extra insulation
and to make the color of the wire black to match the frame
of the motorcycle, but not everyone is as conservative as I am.
1 - 2 of 2 Posts
