Mad Hatter
Is there any one Good with wiring on the older bikes?? I have an 84 Sabre with a issue I just can not get.. If some one can help, PLEASE LMK
ThankX!
Kevin
Run it by me. A lot of the problems on those bikes can be traced to the fuse box under the headlight
Mad Hatter
Long story short, it was dropped at a slow speed and now the Dash, Tail and Tag lights will not work. On the dash the Tail Light indicator is on..
Fuses all look good, bulbs are good..
HELP!
Kevin
check for power at the fuses. On my Sabre, they looked good also, but when I took the fuse box apart all the connections behind the fuses were badly corroded to the point where I had to replace the fuse box. Hope this helps.
Merry Xmas
