The headlamp on my 1800 goes off and then back on. When it's off , sometimes I can switch on the brights , and sometimes the brights don't work either. Light just comes and goes as it pleases.
Anyone else ever have this happen , and if so , what was the problem ?
Do you have a light bar installed on the bike?
From what I've seen here most of the problems are self inflicted leading from an installation of other gear. If not open the headlight and check all the connections, chances are you'll find your problem there. :wink:
I will bet it is your starter switch. Mine has done this as well and I can wiggle or hit the starter when the bike is running and get the light to come on. You should check that if you have not doen any installations.
