1 - 12 of 12 Posts
I'm about to purchase a 2005 vtx 1800 3000 miles the guy never road it. I was wondering if anybody is using any waterless coolant given the fact the bike only has 3000 miles and has been sitting I will be changing all the fluids anyhow. any suggestions as to what I should use? Also hyper charge or not? is it worth it.
I'm sure a post like this will probably end up a lot like a favorite oil thread. Use good antifreeze and follow the directions. There was a problem with silicate components of some antifreeze damaging the seals. Look for "Silicate Free" in the description. Some folks will tell you that you MUST dilute antifreeze 50/50 with water. I really don't know and I've been pouring it in straight since 1973. That could have been what turned my hair silver. I don't know. Never hurt a car and it surely never froze.
Edit: I didn't see the hypercharger question. Don't waste your money unless you really like the way it looks. It's eye candy. Purely for looks, and a profit. We could debate all day on whether it really adds any horsepower but if it does there's no real way to measure it. On a dyno, the bike is standing still. With a properly maintained 1.8 Liter motorcycle engine you have a huge quantity of horsepower more than is needed.
I use Prestone, but as Beezer said - any quality anti-freeze will do the trick. As far as Hyper-Charging.... in my humble opinion, the bike is strong enough as it is. Sounds like you got a GREAT deal on the bike. Last year I picked up my 2007 1800T - with 528 miles on it. Go figure...........
Antifreeze & Hyper Charger
I researched, read 10 jugs of antifreeze at Auto-Zone, then I decided that I would just buy the crap from the dealer and not worry about it.
I have the Pro-R Hyper-charger and I like it too! Roll with what you like!
Very first post is an interesting one:
- No on first question...I suggest research the "How To" board on everything you wish to know about the radiator and coolant. It will also help on the "other fluids" as well.
- A hyper can improve numbers...only because more air is allowed in. It is a very small increase...less than 5%. Allowing more air in can be accomplished in many otherways than paying the bucks for a hyper.
Good luck...what I have seen lately is someone will make their first post a question...then never reply back. I hope you get and/or find the answers you are looking for...keep asking.
Bull
All name brand coolent is silicant free. Color makes no difference. 50/50 mix is recommended by all wrenches and manufacturers. Motorcycle brand name is AD hype.
Evans is the expensive engine ice with same claims. Just pure glycol............
Get some Long Life or extended Life Anti-freeze and use it for 5 years or whatever is specified...
What concentration of water/coolant???
I saw 63% recommended for cold climates on a jug.
http://prestone.com/learn_more/frequently_asked_questions?select_region=1
Q:
What is the best antifreeze/coolant concentration for a vehicle? Can I use 100% antifreeze?
A:
We recommend that you use between a 50% and 70% concentration of antifreeze. At least 50% is necessary to give the adequate amount of corrosion protection, as well as freeze/boil-over protection. However, we do not recommend more than 70% antifreeze. This would cause restriction of the heat transfer capabilities, corrosion protection, and freeze protection. The concentration of freeze/boil-over protection of the antifreeze mixture can be checked using a Prestone® Antifreeze Coolant Tester.
Exactlt Why
Q:
A:
I read all of that too! And rather than become an expert antifreeze, I just bough the right crap from the dealer and I don't worry about anything.
1 - 12 of 12 Posts
