21 - 35 of 35 Posts
Please keep us updated. Every time I read about CA. emissions removal the story ends with "well I put everything back on today". I wish the best as I had come to the conclusion I would have to get a 49 state carb and go that route.
This may sound like a dumb question, but what's the big payoff for this mod??? :dontknow:
I pulled the smog crap off my other bike (VStar 1100) and it improved/reduced the backfiring and allowed it to run a bit richer, same deal here??:confused:
So there is two parts to this: PAIR and Evap system. The PAIR setup is for all bikes and it reduces the backfiring and popping on decel when you have aftermarket pipes. The california emissions stuff can be removed (in my opinion) to reduce the complexity of the bike. It adds three more components that can go bad and tons of places to develop vacuum leaks and other issues. Both of these also clean up the top of the engine making it much easier to work on and do things like valve adjustments.
I have an issue with my elbow right now otherwise I would give it a full on ride test rather than a rev test... I will let you know once I have tested it fully
So, as far as I can tell, the bike is working just as well as it was performance wise. I took it out today for a short ride (about 20 miles) and was cruising easily at an indicated 90 (81 actual) mph with no problem. I might steal some of the pics from this thread and do a full writeup for anyone who would like to do it.
That would be helpful. I do have a few questions on this. If you cap off 11 and 5 on the carb, the open hoses that remain all come off along with the associated plumbing (canister and those 2 valves at the neck). 10 and 6 just remain as vent hoses still attached to the carb, but lead nowhere.
Did I get that right?
So, the only vent hoses are #6 and #1 (gas tank vent). Number 10 leads to two other things: the intake manifold (located between the cylinders opposite the carb, provides the vacuum) and the petcock (allows fuel to flow via a vacuum actuated valve that is the backup to the carb float valve). The number 10 line needs to hook up to both of those with a T fitting.
I removed all of the CA crap along with the PAIR stuff so I didn't have any thing else to hook up. The hose fitting in the air box is plugged and the blockoff plates are installed. Wow did it clean up the underside of the tank and is going to make valve adjustments SOOO much easier.
Thanks. I'll have to look at the bike itself, rather than the drawing from the service manual. My pair valve is gone and I imagine anyone else attempting this mod would probably have theirs off as well.
BTW, once you have the air box off the bike, look at the top behind the vacuum cap (cover for the slider in the carb) and the other is behind the bowl on the bottom. Those are the ones to plug (the are the only things that make the CA carb different from the 49 state). You just plug those, route the vent lines, make sure the vacuum line is good and you can pull it all off pretty much. I think that most people were either plugging too much or plugging too little.
So, as far as I can tell, the bike is working just as well as it was performance wise. I took it out today for a short ride (about 20 miles) and was cruising easily at an indicated 90 (81 actual) mph with no problem.( I might steal some of the pics from this thread and do a full writeup for anyone who would like to do it.
:thumbup:
that would be very help full for those of us that want to do this.and thanks for figurering all this out for everyone.
:tools:
Thanks!
Thanks for the great instructions on how to mod the California model. I started this project and only realized part way through I had a California model and ended up stuck, but managed to come across your thread here on how to do the CA model and managed to get the bike done tonight. Thanks again!
3. Since the hoses are all gone, do I need to put a cap on the left side of the fuel valve?
You'll still need vacumn at that location for fuel to flow. It will start and run for a few seconds with the gas that's in the carb bowl.
You took off to much . I'm looking at Jakes diagram now to help you.
Looks like one of the tees in Jakes diagram is not crossed off, probably the one that runs a line to the fuel shut off valve.
Does anyone have the diagram of what it should look like with evap canister removed?
And what to do with the California version hoses?
I can't find the diagram Mentioned in these conversations.
Post #27 has the emissions and pair vacuum layout.
#10 is the vacuum source from intake manifold to PAIR to EVAP control valve
and to ACO.
ACO and petcock need vacuum... ACO has 2 screws on diaphragm.
Fuel tank vent tube hangs in the breeze after removing the EVAP canister.
The upper body has outside air for the on the 49 state with a very short hose.
it allows air into carb body when slide valve goes up--- between step 4 and 5
of Carb 101 next to fuel hose. A tiny spring clip.
MR VTX carb 101 Carb Cleaning 101
Most everything else could be plugged... MY Guess...
The other CA emissions thread.. 1300 Emissions, PAIR, Calif Evap system
This could be the original thread with pix.
I finished the PAIR mod and EVAP removal on my CA 1300 today (I also added Glen's A/F permanent adjustment screw). I took it out for a ride, and it seems to be working perfectly.
Info on EVAP removal for the 1300s is hard to find, but I figured it out. After I carefully studied the service manual, and from all the info I could glean from miscellaneous posts, the manual, and sheer intuition, here's my step-by-step procedure - after seat/tank/cover removal and PAIR mod (if you don't know how to do these things, please do not proceed, cuz it only gets harder):
(Before you begin, identify everything associated with the EVAP system - the service manual is indispensable. If you did the PAIR mod, you're ahead.)
I started with un-bolting the EVAP canister under the bike. I disconnected the skinny hose (that goes to the gas tank) from the canister, but left the other two on. However, in order to separate the EVAP canister from the bike, you need to disconnect that fat (#4) line that connects it to the CAV valve (at the neck of the bike). If you did the PAIR mod, you ought to know what I mean.
After that, I removed both the EVAP CAV and Purge control valves at the neck, leaving the vac lines in place (while I was figuring out what to do next). When all was said and done, I only had left a few vac lines connected to the carb and intake manifold. These were the tricky ones to figure out since the info on the forums is mostly for 1800s, and the service manual took some deciphering.
I made this diagram for myself using the image from the manual, which can also be found on the rear fender under the seat (I was inspired by this old post by BSAMAN, as evidenced in the text in the image):
From BSAMAN, I learned not to disconnect and cap the #6 line (right next to the fuel line into the carb). I don't know why it couldn't just be left open with no hose attached, but as is, it works fine.
On the side of carb towards the front of the bike is a #10 line. Pull this and cap it with a 1/8" vacuum cap (these are hard to find in SF, but I begged a good friend in the service dept. at a local bike shop for them). It wouldn't hurt to have a few on hand (5 or more):
Here's what it looks like capped:
After that, I pulled all of the rest of the #10 lines at the top. I tried to pull the line going into the intake manifold, but it was on there good, and I was also short a vac cap, so I just plugged it with a screw I had on had from another project (TIP: never get rid of anything, cuz you never know when you'll need it! that said, when I get some more vac cap, I will remedy this blight).
The last step was to remove the line going into the backside (and bottom) of the carb. It was hard to get to - and if you have large hands, you'll need to get some better tools), but it was easier than I expected. You have to pull this line, then cap with a 1/8" vac cap. (or, if you're lazy and you have the right size screw, just plug it and zip-tie it off. but I don't recommend that).
Disclaimer: I am not a mechanic, I'm just not stupid. Don't take this as professional advice because I may have it wrong. But from real world experience, the bike runs better than it did before I made these mods, as I had hoped based on what others have reported. Who know what issues I may encounter down the road, but all seems good so far from my test rides. The exhaust sounds better, the bike looks cleaner, and I feel great from solving this problem with the help from the great community plus good old fashioned ingenuity.
If you have any questions, let me know. Here's a link to higher rez images:
http://www.flickr.com/photos/[email protected]/sets/72157622555738115/
-eviljake
That link has expired you don't have that diagram you met made up to the smog the canister the vent valve and other vacuum lines.
Deciphering the manual is about useless I think they do that on purpose so you can't do smog from California's bike thank you
Post #33 All 3 links open for me.
1st one vacuum hose routing.
A thread in our Howto;
21 - 35 of 35 Posts
