i just purchased a set of American Classic Pipes
from an individual..without the mounting bracket...i have looked everywhere for this item...is it possible to use an alternative bracket? i need some advice..i ride an 02 1800c
contact the factory or the importer, supplier
Welcome....Is it possible They used the factory bracket...a few aftermarket do......good luck
Never heard that name. Inspect the pipes carefully, may have some numbers stamped on it. Most pipes are made to use the OEM bracket. You can always make a bracket or have one made for you. Hardkrome has numbers stamped on a bracket from outer shield to exhaust pipe near the bracket mount...
yes part number is stamped on it 38-2060...trying to contact hard krome but cant get anybody..do u think they mite use the oem bracket?
Looking at the Hard Krome website for the 38-2060's you bought, there's a pic of the pipes and the bracket that comes with it. Looks simple enough to make if it's just flat plate. Then again giving a call to their shop in Anaheim may get you a brand new one assuming Covid hasn't shut them down.
