What are external crossovers? Would they work in a Stealth fairing with the four speaker cutout and a nitro amp? If you can get it at a good price would you do it?
Just curious as I'm patiently waiting to get my setup eventually done.
external crossovers are basically capacitors that block certain frequencies so that smaller speakers don't try to play bass they aren't designed to play. you can buy them at any car audio shop
Depends...
If you are going to run the same speaker for all 4 speakers then, as already stated, just a good radio with an EQ will work just fine. IF you are going to run 2 bass speakers and 2 mid range (dual axial) speakers (one each on each side) then running a crossover (one for each side) would send the bass to the thumpers and the rest to the regular speakers. Just depends on how deep you want to get into it. Good luck with your project...
