I'm going to be installing the Kury Valk grips on my X. For reasons I won't go into detail on right now, these are to be mounted about one-half inch or so from the switch housing on both the left and right bar ends. Where can I get additional spacers to fill this larger gap at the ends of the grips?
Try useing 1/2 or 3/4 inch pvc "water line " pipe and just cut it to the length you need.
Good Luck !!
Bareass172 said:
Yeah, anything that is about 1" outside diameter should work fine. :wink:
So the ends of the grips won't feel "bendy" with spacers unattached to the bar/bar ends?
Bump. :oops: :bump:
Bill F.
Nah you shouldn't feel bendy on the end. I have VAlk grips. and did put 1" pvc on the end. and works great! you wont notice it. good luck 8)
Ridesafe 8)
