07 VTX 1800 F around 40 degrees in morning the F1 light comes on after bout 5 miles. Bike seems fine on 50 mile ride to work. After work it's around 55 degrees out. The light doesn't go on. Any idea what is going on? As long as it is above 50 it hasn't lite
Does the light stay on when it comes on, or dies it just flash then go back out?
If the ECU is recording an event, with the bike in neutral, on its side stand, turn the key on, but don't start it, and count the FI light flashes.
This will be a recorded trouble code.
Then you can look in a service manual and see what is going on.
under the gas tank, left side, near front, rubber boot over 2 sets of wires,
inside rubber boot, are 2 connectors, check that the wires are tight in the connectors. and if water is inside of connectors.
Tank DOES NOT need to be removed.
I had problems with water getting inside the rubber boot.
1. Tighten your battery cables
2. Do the ground fix, paying attention only to the "Common Electronics Ground" section as seen on the "How To;Step-by-Step" board here
http://www.vtxoa.com/forums/showthread.php?t=205905
These are the Top 2 reasons for your symptoms
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://tech.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://vtx1300tips.com/VTX1300TIPS.htm another fellow VTX Riders site.
