The cooling fan wires just started smoking and burnt the insulation off of them when bike was cold.
Has anyone else experienced this ?
I'm curious if mice are the insulation off the wires causing them to short 馃
Looks like I need to pull the tank so I can inspect the entire harnes and find out where they started getting hot. Shouldn't be too hard cutting back until I find nice unburntcopper wire .
Any input would be greatly appreciated.
Thanx
In
Advance
Replace the fuse while you're at it. Use the recommended amperage. Obviously the one in there now isn't doing it's job.
Trike?? Does is have a manual switch to turn on the fan??
Does the fan motor turn freely???
