just undo the wiring than remove all the allen head strut bolts than remove the shocks and the bolt the shock bolts to at the top of the shock, it takes a large allen wrench, and it will come right off.TimmyG said:can someone point me were to look to remove the inner fender on c model
If he is talking about the license plate bracket, that is correct. Can be removed with a Dremel.Steelhorseman said:If I am not mistaken, that is welded on.
steel
oh, oops. i cut off as much as i could with bolt cutters than used a sawzall.TimmyG said:i was talking about the inner part that holds the plate and turn signals
