Hello,
I was wondering if anyone has experienced the same problem I am currently having with my FI light. At high speeds the light will occasionaly come on and the bike will lose power for just a second or two and then everything returns to normal. I have also experienced it at lower speeds while decelerating. At first I thought it may be ethanol in some gas I had put in, that was not it. I then changed the plugs and thought that had fixed it for awhile, not so. Today I rode an hour one way and had no problems. However, on the return trip the light came on again for about three seconds and then never came on again. Other than this issue the bike is running great. Any ideas on this? Any help would be greatly appreciated before I start throwing money at the dealership.
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://vtx1300tips.com/VTX1300TIPS.htm another fellow VTX Riders site.
Thanks for the advice. I have found the ground fix post and will do that this weekend as well as check the battery connections. Can't thank you enough for the advice.
Replaced battery, it was overdue, and did the ground fix. The bike is running better than I can remember in the five years I've have had it. No more power loss or FI light coming on. Thanks for the help.
