???? for those with Frogg Toggs
405 views 2 replies 3 participants last post by  Pat Forster
#1 ·
Getting ready to order some, need some advice. On the site it has the following:
Large 5'6" - 6'3" 150-190 lbs
XLarge 5'10" - 6'5" 190-230 lbs
I am 5'10", right at 200 lbs. What would fit better, the Large or the XLarge? Are they cut bigger than normal to allow for what youre wearing under? Thanks.
#2 ·
frog togs
Get the largest size you can. That way they are easier to put on when the rain starts. I keep a set in my T-bag on th ebike an dthey have saved the day for me several times. I know they are not as durable as some other gear, but they work for me and that is all that I care about.
#3 ·
I would get the X-Large. If they offer the kit to stop the pipes from burning a hole int he leg, get it. If not, cut a piece from an ironing board cover and glue it inside the leg. I don't know if you know this or not, but Academy sells the Frogg Toggs. You could try them on there.
Pat
