I change out the fluid and seals then reinstalled the Left and Right forks. they are nearly flush with the tree. I installed the axle to check the alignment and it was way off. Probably 3/8's or better. Tried adjusting the nut under the cap but to achieve the proper length I would only have 2 or 3 threads holding the cap on. I have read that this has been seen before and Bareass Chopper has a write up on the adjustment and he mentions that the other side can be adjusted also. However it doesn't say how to do it. Anyone else seen this and fixed it.
