Hi, I have a 2003 1800C. The bike had been sitting for awhile(over a year). I pulled the bike out, put in a fresh battery, checked other fluids such as oil and coolant, put gas in the tank and turned the key and started the bike. It started relatively easy. The bike ran kinda rough for about 30 seconds to a minute and then purred like a kitten. I revved the throttle several time and it responded well. I stopped and restarted the bike several times and then allowed to run for about 5 minutes. I then killed the engine and began cleaning up my mess with the intention of going for a ride after the clean up.
I started the bike up again to go on my ride. As I pulled from my drive-way I noticed the bike beginning to run rough. I thought that it was probably just from sitting and needed to be ran. I made it about half a mile to a stop sign where it died and would not restart. So I pushed it the 1/2 mile (uphill at that) back home and let it sit over night. Upon trying again today as I tried to start the bike I noticed fuel pouring from my exhaust. I disconnected the tank and removed 2 plugs and blew an enormous amount of fuel from both jugs. I replaced the plugs and with out reinstalling the tank I turned pressed the start button and the engine started briefly on the residual fuel in the combustion chamber.
I reinstalled the tank and tried to start the engine with the same problem as before, fuel began pouring from my exhaust and the engine would not start.
Any help here would be most appreciated.
Thanx
Thanx
