OK so my 03 VTX 1800 "C" has a 4.7 gal tank, Reserve light is suppose to come with about .79 gls left in the tank, Twice now it has come on and I filled it it only took a little over 3 gls. Any one else have a reserve light that comes on early?
If you don't trust, or want to rely on the light, mark your miles traveled. Fully fill the tank. Fill a safe gas-proof container, and somehow carry it with you. Run the bike until it dies from starvation. Check your miles, refill and get to a gas station. Adjust your riding accordingly.OK so my 03 VTX 1800 "C" has a 4.7 gal tank, Reserve light is suppose to come with about .79 gls left in the tank, Twice now it has come on and I filled it it only took a little over 3 gls. Any one else have a reserve light that comes on early?
Yes this is normal and I like it knowing I can still ride about 50 km before I run out of gas.OK so my 03 VTX 1800 "C" has a 4.7 gal tank, Reserve light is suppose to come with about .79 gls left in the tank, Twice now it has come on and I filled it it only took a little over 3 gls. Any one else have a reserve light that comes on early?
I also have a C model but when my reserve light comes on there is still about one gallon left before running out of gas.If you got a 4.7gal tank, you are one lucky duck. Most of us have only 3.5 gal tanks with 1/2 gal reserve which means you put only 3 gals in if the light comes on.
When my fuel light comes on and I have only 0.5gal left, that gives me 15 miles to get to a pump. I recently did that, got to a pump 15 miles after the light turned on and the bike died right there. Talk about lucky.
So I agree, have a procedure in place, count miles driven on the odometer or be ready to fill up right after the light comes on.
Bareasschoppers Fuel Pump Light ModIf you don't trust, or want to rely on the light, mark your miles traveled. Fully fill the tank. Fill a safe gas-proof container, and somehow carry it with you. Run the bike until it dies from starvation. Check your miles, refill and get to a gas station. Adjust your riding accordingly.
I finally tested my fuel capacity and reserve fuel last weekend. On my 02 C model I have exactly 4.5 gal of usable fuel and 34 miles of range once the light comes on doing 70 mph. I wasn't expecting that much reserve range. My total range to empty appears to be 160 miles which isn't terrible. Still has me wishing for the larger 5.3 gal tank though...OK so my 03 VTX 1800 "C" has a 4.7 gal tank, Reserve light is suppose to come with about .79 gls left in the tank, Twice now it has come on and I filled it it only took a little over 3 gls. Any one else have a reserve light that comes on early?
The first time this happened to me (2003 1800s) it scared the bejeebers out of me until I figured out that this will happen 1) during braking, 2) during braking while going downhill. Living in Colorado #2 happens a lot.When my fuel light comes on and I have only 0.5gal left, that gives me 15 miles to get to a pump. I recently did that, got to a pump 15 miles after the light turned on and the bike died right there.
And yet it sometimes happens. The few instances I have heard of this happening, and it happened at least once to my buddy Renegade Rick and his 'S', when his light burned out. Upon refilling there WERE no issues.Bareasschoppers Fuel Pump Light Mod
Tim says:
December 22, 2011 at 9:54 AM
Great write-up, thanks! Also, just a thought on your comment about running the tank until empty after the mod and carrying around a spare jar of gas….This engine is fuel injected, so I wouldn’t recommend ever running it down to empty. Aside from fouling the injectors, it could also damage your fuel pump.
2003 VTX 1800C service manual says tank capacity: 17 liter=4.49 galLou VTX, the owners manual says it has a 4.7 gl tank. so I'm not lucky, that is what it came with. I don't like to run out of fuel, not good on the fuel pump. I have owned about 22 bikes and I always see how far I can go safely on tank of gas. I always stop as soon as the low fuel light comes on if not sooner. I always fill up before I park it at home so I'm ready to go next time.
A 2003 C model does NOT have a 4.7 tank. As said above, they have a 4.4 gallon cell. This includes the reserve after the Low Fuel light comes on. So that puts the tank at around 3.7 gallons.Lou VTX, the owners manual says it has a 4.7 gl tank. so I'm not lucky, that is what it came with. I don't like to run out of fuel, not good on the fuel pump. I have owned about 22 bikes and I always see how far I can go safely on tank of gas. I always stop as soon as the low fuel light comes on if not sooner. I always fill up before I park it at home so I'm ready to go next time.
What I said..A 2003 C model does NOT have a 4.7 tank. As said above, they have a 4.4 gallon cell. This includes the reserve after the Low Fuel light comes on. So that puts the tank at around 3.7 gallons.
The later 1800C versions like yours seem to have a larger tank capacity of 4.8 gallons: 2006 Honda VTX1800C- Specifications (hondanews.com)I have a 2006 VTX1800C2 and it's fuel is as stated is 4.49 US gallons. I have DriverDiary app on phone and I use it on every vehicle I own. After every fill-up I put in Gallons, cost, and odometer reading and Zero my trip meter. I always see what my MPG is. MPG times 4.49 gives me when I will run out of gas. Only variable is how easy or hard I ride. Now I've gone as bad as 32 mpg, and as good as 44 mpg. Miles goes from 143 to 197 miles on a tank. My current average is 39-40 mpg. So as long as I fill up by 150-160 miles and I'm not hotriding it, I'm good.
Have 2003, 1800 C with 82,000 miles. My fuel light seems to be somewhat intermittent and seems to vary but usually comes on at around 3 (faint)-3.5(brighter) gal to fill. Have to agree with the odometer setting method unless you drive exactly the same way and your plugs, air filter, tire inflation, etc. are in the exact same condition when you run it dry for some exact mileage determination. Bike usually lets me know in the 3.5 gal range by wanting to shut off when stopping. My mileage varies greatly depending on around town (always jumping on it) or highway (occasionally jumping on it). With my bike when my trip odometer gets around 90 mi, I start looking for fuel and know that if I've been solely highway driving on that tank I can price shop. Only had a close call once, on the skyline drive-North Blue ridge, on a Sunday (last station open on the Skyline), when I had to freewheel down towards Lynchburg from the Peaks of Otter. Otherwise the 90 mile start looking method has worked for me with my bike.OK so my 03 VTX 1800 "C" has a 4.7 gal tank, Reserve light is suppose to come with about .79 gls left in the tank, Twice now it has come on and I filled it it only took a little over 3 gls. Any one else have a reserve light that comes on early?
