first all why do you need a fuel pump on the 1300? it's not fI the tank is above the carb. why not just gravity flow.has anyone tried to bypass fuel pump.....if so what was your results....trell
Take it off if you want,it's NOT needed! IMHO just something else to fail & leave you stranded! You X has one carb & don't need a pump to feed it! I think only some of the 03's had it & it was then discontinued........ :D Rod
Only the inital '03 1300's had a pump and they were gone by the middle of the model year run. It was a carry-over from the 1800 design that was used to create the 1300 and Honda figured out it wasn't needed after the fact. All late '03 models through today use a vacuum activated petcock that opens the gravity feed.
