So I did a search and couldn’t find an answer to this. I have a 2002 1800. Just got the tank back on it today and went for a ride after filling up. Ran fine. I got home about 50 miles later and parked it. Came back to the garage 30 minutes later and noticed the gurgling sound coming from the tank and a puddle of gas under the tank vent tube under the bike. After looking I saw it suggested that the gurgling was fuel returning to the tank from fpr. It is definitely not cooling system as the sound and the drip goes away as soon as I remove the fuel cap. Any suggestions?
Had my 2004 1800 do it once, it was very hot and parked it in the garage and noticed the gurgle and leak at vent, didnt change opening gas cap, never happened again. Dont think I would worry about it.
Discussion Starter #4
Mine stops when I open the cap so I’m assuming it is the fpr releasing pressure through the return line. Noise and drip stopped with cap open. I just didn’t think it was full enough to force gas out the vent.
Just got the tank back on???
A problem?? Looks like the tank has been cut open.
When you removed the fuel cap did you notice pressure releasing?
Was the gas leaking from the vent hose or just happen to use that hose since it was going down?
Fuel leaking from fp mounting plate seal possibly.
I remember reading of an 1800 with FPR return hose blocked (hose ID blocked from rubber deterioration)
I believe the FP also made a whine noise.
Discussion Starter #7
The pic is not my tank. Just for reference.
Figured out the problem. When my uncle expanded this tank, I guess he cut through the vent tube. I was able to find the top of it after pulling the fuel pump. It is now on the left side so when it sits on the kick stand and is almost full, the fuel can be forced out of the tube. I cut the tube shorter and reran it back to the top front of the right side so It won't do it again. Filled it all the way up, ran it, and parked it. All better now.
