I just ordered a disconnect for the gas tank return line.Has anyone put one on the main fuel line?Will they take the pressure?Not sure what the pressure is anyway.Thanks.I did order the chrome plated brass one.
I have the plastic (Acetal) on both lines for over a year now,no leaks,no problems...
The pressure side is about 50 psi. Do you really want the chance of spraying fuel under your legs at 50 psi on a hot bike??? Do you know what the flash point of 87 octane fuel is??? I would recomend you only use the quick release valves on the return lines :wink:
Chiefrider said:
That was kinda my thought.Don't need that! :cry:
The line come off easy enough with a 17mm wrench from the regulator :wink:
