1 - 20 of 31 Posts
That sounds a little large, but if it fits, it will look nuts.
As far as install, I remember having to tilt the tire up into the fender, but I have an R. Your mileage may vary.
Reactions: Blast
I would stick with a 205 or narrower. I actually went with a 195. I have a 1300 R.
I went with a Bridgstone Driveguard which is a runflat. The stiff sidewall made for a much better experience than the General tire initially tried (I gave up on that tire after 500 miles).
As previously stated take it easy there will be a learning curve with that wide CT especially on uneven surfaces. Went darkside twelve years ago and don't regret it. Ride safe
2006 1800S VTX
I believe that is the size tire I put on my 1800F. I had to cut off the helmet lock to fit the tire. Otherwise no problems mounting it.
So the 215 doesn't rub, great to know (considering dark side later).
But what about 2-up? With extra weight and extra sag, would the different profile and increased width rub then?
With all that contact, you will be loading up the cross-shaft pretty good doing burnouts.
Reactions: Lou_VTX
I've been running a CT for years (205/60/16) and have not had any rubbing issues with a date on the pillion. Course I like petite women so who knows if you had a real side of beef on there. Bwa-ha-ha!
Reactions: rangers4u
05 1800, 215/45-18 ....any install tips?...seems huge, but the internet says it fits, so I have that going for me.....
General Altimax RT43 205-65-16 radial on my 1800 C. 40 psi, Progressive 444 shocks. Ride-On gel internal balancer/ sealer, 2- 8 oz. bottles. 90* steel valve stem. Once the tire was mounted and aired up, I deflated it to get it up under the fender, then re-aired it. With the wheel off, excellent time to get rid of road debris, pitting, scuff, by sanding and or polishing.
All right! A dark side thread! Now we just need an oil thread!
nothing like fighting about nothing to bring us together.
1 - 20 of 31 Posts
